square tube thickness for frame
dodgecrawler2011
What tube thickness is ideal for a frame build from scratch. Plan on building it out of 2x3 square tube. It will be on rockwells and a less then stock 318. It will be full bodied still but light.
I'd say atleast 1/4" minimum 3/16"
Re: Re: square tube thickness for frame
I'd say 3/16 would be plenty...
My bentfab chassis is 1/8 with a formed 3/16 subframe/link mounts. And has a 3/16 skid under it that wraps around the subframe, so it's 3/8 where rocks will hit.
What is a less than stock 318?? Them thangs was dogs stock, I bet less than stock really sux. whatyadoo pull some plug wires off??
Oh and another 3/16ths vote!!
Ha it has over 300xxx miles. Its a turd but runs 185 all day long sips gas and is reliable. Low side is always engaged.
The buggy I'm building now I used 1/4" 2x4 on the belly area where links attach and it will take hard rock hits. 3/16" 2x3 for the rest. The weight differnce isn't that much to make it thicker in critical spots.
