mark
2005 F550, 6.0 diesel. "New" truck to me. Died on me first time using it, batteries went flat. Had 10V at the batteries. Figured bad alternator so I swapped it out. Still no charge. Traced the wiring to the battery isolator (has auxsilery battery's). It appears I lost one side of the isolator. Checked voltage out of the alt and I had 20 Volts! Changed back to the original alt and it was also putting out 20 Volts. Took both alt to the auto parts store and both checked out with a max voltage of ~15.6.
What do I look at? I'm running out of time, I need to use the truck Wednesday night. I don't know if I have time for the dealer down the street to look at it. I plan on pulling the batt wire for the alt and see what I have without the isolater. Also going to try running a remote ground from the neg term to the alt case and see if that makes a difference.
