Tbi question
Yes X2 but you'll loose timing control unless you do some distributor mods. Then it wouldn't be a HEI any more would it?:haha: You have to do some minor harness mods too......I would use a TBI dist if I were you.
I have TBI and a Mallory HEI on my 401. NO timing control (by the tbi computer) but i think the new Howell kits do have timing control now.
Afforable-fuel-injection's TBI kits come with an HEI ditributor with full ECM control.
I have always had good luck with the hei. Thats all.
In that case, you can run an HEI with the 7-pin module. Externally, it looks like your run of the mill large cap HEI with the integrated coil. Only difference is no mechanical or vacuum advance and a different module with another 4-wire pigtail sticking out. Look on mid 80's EFI or carbed rigs with the electronic spark control. No vacuum advance diaphram is a giveaway.
i use the 7 pin HEI on my blazer,plugs right into my holley injection. came off of a 82-86 chevys with the ESC electronic spark control..pickups,blazers and burbs,mostly with the 305 motor.
Affordable?
Define affordable... :D
