Th350 no reverse
09zkrankin
catlettsburg KY
Finished up the trans for my yj and went to back it out of the garage, no reverse. Not sure what went wrong with it. I used the b&m transkit, with shift kit, all clearances set to spec, new direct drum, new forward drum, new tailshaft, new converter, thought I did everything right but I guess not. Anybody had this issue or got any idea what it may be? I saw on another forum people saying it may be in the valve body, that's what I'm hoping. Hoping it's not in the sprag or something since that will require full disassembly. Thanks for any help
Sent from my iPad using Tapatalk
Well turns out that one of the seals on the pump had came loose when we installed it and was not putting pressure to the direct clutch, therefore no reverse
Sent from my SAMSUNG-SGH-I747 using Tapatalk
