Tire Cuts
bushhog750
I picked up a pair of used but still about 90% tread 43'' SX Sticky's today and one tire has a cut almost half way around the tire at the rim area. Its cut all the way thru the first layer but not into the second layer. Its not one solid cut but a combination of cuts 3-5" long that run around about an inch away from where the wheel meets the tire. I've heard that the sidewalls in these tires are pretty tough, should I be concerned with this and go ahead and have it vulcanized or run it until it gives me a problem and then fix it. Any suggestions.
That's good to hear. I don't think it would be an issue but I just wanted some different opinions.
