what did you do about pinion angle on the front and rear?
Front Pinion adjustable by the 3rd link.
Rear adjustable by the upper links.
Or did not that answer what your looking for?
Thought that was your question.
I tried to set them up as stock. Thinking the front was, well I don't remember now. It will come to me.
I've used dynatrac mostly, some currie, and also clayton. claytons stuff is definitely no frills burley **** that seems to go together pretty easy. I'd also check out teraflex, they've got some pretty nifty well engineered stuff. Eventually though after using the different manufacturers I ended up fabbing up my own brackets that allowed for more ground clearance.
