outhouse
do they have an internal regulator? and what is the 12 volt reference? its on a 88 22re with an ORS harness.
OK, I'm going to bite. What is 12 volt reference? I googled and only got that it related to the sense circuit.
the 12v reference goes to the battery hot all the time and the 12v ignition needs to be switched power "It's the one that activates the regulator on"
so the 12v reference and the charging wire both go to the battery?
What are you trying to do? You can hook it to the battery but depending on what you are trying to do, using the factory sense circuit may be better.
If you don't have a butt load of power aseccaries (I can't spell) Than run it off the battery/ main charge wire. otherwise the sense circuit comes from further up the wiring harness from a rather mystical way, **** I don't know. What type alt are you wanting to run?
the ignition 12v wakes the alternator up so the regulator starts working.
the 12 volt reference tells the alternator what voltage the battery is at so it can regulate how strong of a field needs to be generated. just run the wire to the battery and all will be happy
so the ignition 12v needs to go to a switch i.e. ignition switch or toggle(just remember to turn it on)
the 12v reference need to go the battery
the charge wire also needs to go to the battery
and if you want to put a warning light on it thats where the other wire goes
