Glenn
Hi
2001 Toyota Tacoma with TRD package.
The rear differential lock light is flashing and will not go off even with the lever in the 2wd position.
It is a rapid ON flash.
When I got the truck, it had a different problem with a switch in the rear differential system and it had a different flash that was even between its ON and OFF cycles. It would also stop flashing when shifted to 2wd. That problem was fixed.
I now have a different issue and I am not sure what it is. The truck does not seem to behave as if it were locked when in 2wd.
Any ideas what is going on? I have searched the webz and can find plenty of discussions about the locker not engaging.
Thanks.
Thanks.
