85buggy
Is there room to pass ?
The one ton Toyotas. Or the dual wheel ones at least
Worth buying or building. Any body ever used one ?
bluetoy said:If you're wanting an upgrade form the 8" diff, I would look at either a Tacoma 8.4" or a Land Cruiser 9.5". Both of those are easily found and stronger than an 8".![]()
billstoy said:I run fj40 91/2" stuff I sheered off a old 6 spline pinion but the new fine splines have much more meat. they are good but I may watch for a fj80 LC rear for updated stuff and stock rear discs ! or build a hybrid with LC center and IFS outers and bearings It's all cheaper and lighter than the other stuff !
I have a pile of broke r&p that prove that.... But I'll keep tryingTBItoy said:...I don't think the 8" rear will hold up to 39 reds
billstoy said:Dam that was a good idea I had but someone did it first.
jordan7118 said:I agree. FF 9.5" rear is the way to go.
Nick, you have a build thread on your hybrid front. I know Eric Hagan did one similar a couple years ago.
TBItoy said:I'm doing a hybrid rear. I'll probably add it to the gremlin thread on pirate when I get it done
I considered doing a hybrid front like eric's, but decided against it.
I'm running a HP front and 30 spliners in this rig, so the front should be "ok" till I'm hard on it
D'oh! Sorry. Misread that :embarrassed:TBItoy said:I'm doing a hybrid rear.
