extremetownie
- Joined
- Apr 7, 2009
- Messages
- 680
Do i need a track bar on a jeep wrangler with a double ended ram?
It depends on your suspension, not your steering. If you have a triangulated 4 link no. If you have a 3 link, or parallel 4 link then yes.Do i need a track bar on a jeep wrangler with a double ended ram?
Keep the angles as close as possible and you’ll be good.I am going to run a servo and keep the stock box. I am ready to put the ram on and the track bar is in the way. I guess i will raise it to go over the ram and keep it as long as possible. It is on the race jeep.
It doesn't have to attach there. They just need to be as close as possible to the same length and as parallel as possible. You'll likely have to move your frame side mount outside the frame rail using a bracket like this, or build your own.My drag link goes to my knuckle , attached to the high steer. There is no way i can get the track bar over there.
