Sold/Expired Tube Buggy $11,000
AShearer
Member
Chassis: 1 ¾ welded seem tubing
4 link front and rear, bottom links 3/8 wall DOM tubing, upper links .120 wall welded seem tubing
QA1 chromoly heims
Chevy 350 with Comp cam kit, headers, roller lifters
T350 with stall converter and B&M shift kit, Art Carr shifter
Twin Stick np205
Sway-A-Way Racerunner air shocks
Front end: Dana 60, 6:17 gears, Detroit locker, hydraulic steering, 35 spline stubs with drive flanges
Rear end: hybrid axle; Dana 60 differential with 14 bolt axles, 6:17 gears, welded
Wheels and tires: 44" TSL front Bogger rear on 15” MRT 32 beadlocks
Warn 8274 winch with new 6 hp motor
Plastic race seats (black covers included but not pictured) with 5 point harness
Propane conversion with aluminum 40 LB and 30 LB tanks (extra aluminum 40 LB tank included)
Heavy duty custom driveshafts front and rear
Rear mounted radiator with dual electric fans
Transmission and power steering coolers
115" wheelbase
I built this buggy for the hills of TN and AL while living in Chattanooga. I have since been relocated and no longer have time to ride. The buggy is currently located in central Florida.
-Adam
$11,000 obo
Also, trailer for sale: all steel diamond plate tandem axle trailer with reinforced diamond plated fenders so you can drive over them. Includes slide out ramps. $1,200 obo
Considered trades and would a 6'9 person fit
I'm 6'1" and I have plenty of room. It's hard for me to say if a 6'9" person would fit because it all depends on where the height is at. If you have a taller upper body you would probably fit as it sits right now because it has good head room. If your a guy with longer legs you might need to raise the seats a little bit to get the extra leg room, but either way I think it could work.
I'm not really looking to trade for anything. Let me know if you have any additional questions.
