blacksheep10 said:ECGS was doing it. I got one of their 5.13's
how, did you use a flap-disk?COPPERHEAD42 said:Pretty easy to do it yourself, I have done a couple only takes 15 to 20 min
drich394 said:how, did you use a flap-disk?
COPPERHEAD42 said:No regular grinding wheel, put ring gear in lathe, got it spinning and started grindin
drich394 said:
not laughing, just wanting to see the finished product, id thought about flap-disking mine down after reading a few people over on Pirate doing it, im all for it, Cheaper the better!!InDaShop said:Laugh but the **** works.
Elliott said:I'm lost here if you had a lathe why not just machine it?
TBItoy said:Because ring gears are made of heat treated 8620 usually.
You'll tear up a ton of tooling just trying to cut it.
A toolmaker buddy of mine had the same thoughts and after popping a couple carbides, took a grinder too it.
Elliott said:I'm a toolmaker also, if you get the speeds right you can cut it no problem.I would hate to have to grind it off but have to do ya own thang, what ever works.
