what is a good combo for 355 chevy on propane , thinking of goin Jeggs vortec kit undecided on which cam will give me the best for the sport ??? running th 350
Any help would b appreciated
We just did this to bugej's motor t near doubled the power shaved the heads a lot near 11:1 comp ,mild cam to keep vac for propane! Ill try and get the cam number it's a comp cam.
Check with Patriot performance in Rainbow City, they had a smoking deal a couple years ago, they took new vortec castings, put stainless 2.02, 1.60 valves, screw in studs, 5 angle valve job, mild porting, big springs, and drill the heads to accept old style valve covers, or the centerbolt, and drill to accept old and new style intakes, i put a set on a hot rod boat engine, loved them, think they were around 650.00 cant beat that
thanks for all the input guys :****: im still looking and will take any info u got !!! im leaning towards the SCROGGINGS DICKEY Co. they sell vortec head kits , comes with lt4/ z28 spring hardware,rocker arms up to .525 lift i believe a eldebrock performer intake all the bolts and gaskets ????? any body delt with the Co.
Thanks in advance for any further info .
Finally found the cam specs! Spent around $1100 for gaskets, head bolts, reman heads plus machine work( drilled for old style intake and shaved for high compression) cam kit w lifters, oil pump, timing chain, and tune up!
I think that is one of their Extreme Energy cams. It is a great cam for a 355 with good vacuum. I wouldnt go any larger though. We are running one in a 355 with Edelbrock heads and it is pretty stout. Also tried to run one with their 12-254 grind, way too much duration for decent vacuum.
