Do you suspect the 02 sensor is bad or it's just throwing a code? If you recently replaced the sensor and it worked for a while then quit look for chafed and grounded wires all the way back to the connector then to the controller. Check both connections for loose wires or pins at the controller. If the sensor is bad the first thing to suspect is moisture, make sure the bung is as top side in the pipe as you can get it. If the sensor was old I would say to clean it with non-ethanol gas soaked overnight and scrubbed with the wife's tooth brush, before replacing, the sensor not the toothbrush. Otherwise they are pretty tough about the only other fail cause is a spike in power, they work on very low power something like 0-5v and signal back to the controller where the circuit is completed thru the grounding of the controller. Which brings up a good point, check your grounds for the controller. Holley mandates ground to a head and recommends a jumper to the other head. RTR
