Not Jobless
Mr Funbags
Is this based on the weakest link in the system?
Rear diff?
HP/TQ?
Tranny?
Tire load range?
Rear diff?
HP/TQ?
Tranny?
Tire load range?
The rating is something a manufacturer puts up to keep thier ass out of hot water.
They're ancient terms that don't really apply anymore.so how about the terms 1/2 ton, 3/4 ton, 1 ton? What is this measuring? I've always wondered.
I believe at one time these numbers refered to how much weight you could haul in the bed of the truck and had little to do with tow ratings. Even today they don't always reflect the tow ratings. My truck for example is a 3/4 ton and has the exact same tow rating as the same year one ton.
Tow rating or GVWR?
Both.
alright did I miss something? A 1 ton weighs more.. right? At least for Dodges they do. So they wouldn't have the same GVWR and tow rating..
Gross as in vehicle, camper, trailer, occupants all combined. You may call it gross combined, I'de have to go look it up to see what Ford calls it.....
Basically a one ton can haul a heavier camper but you have to then reduce that weight difference from the trailer to stay below gross weight. IIRC it's 21,500 lbs all things combined. Trailer weight or towing weight has a max also which is the same for 3/4 and one tons.
Rear diff?
HP/TQ?
Tranny?
Tire load range?
Simply put, it means we will constantly overload our junk as we think it'll be "just fine", right up until the hitch rips off the frame!!!!:awesomework:
at least Dodge recalled that problem :haha:
