longfield
Looks good, nice work mister. :awesomework:
I made an atempt at getting the front suspension done but I'm still not there. I moved the panhard bar as much as I could bu just threading the johny joint end in all the way and modifying the frame mount, but then the coil hit the edge of the bracket not just the bolt head :looser: so I cut the end off the panhard, machined a new piece and welded it on making the panhard 1 1/2" shorter than it was originaly. With that isue resolved I started work on mounting the shocks. First I checked all the clearnces/ mount off the inside or outside
Checking clearnce.
[/IMG]
So I had tire clearnce to mount the shocks on the outside, but the steering arms would have hit them at full turn so I went with inside.
I'm starting to get tired of making all these little tabs
[/IMG]
Its worth the time to just have him cut them out for you. http://www.nw-wheelers.com/forum/showthread.php?t=42313
are you gonna put some steering stops on that axle?
Any progress
Yes.
Dang that thing sits nice and low! Very nice work as usual!
Measured it against a 89 with a 4" ifs lift and 33's. Mine sits 2 1/2" lower with 35's :awesomework:
