I've got the below rotors for my Spider9 front axle but after wheeling with a few guys up in Canada that have the same, I'm not sure I'll be able to stand all the squealing/squeaking caused by these getting wet/dirty.
Who might be able to cut me the same design w/out the holes?
I believe it's 3/8" mild steel w/ no special processing according to the Spidertrax rep I spoke to today.
Terry
Mild steel for brake rotors :haha::haha:
Every OEM rotor produced is an alloy of sorts..
Okay smarty pants... I'm just repeating what I was told. I'm not an expert in the properties of metal.
I've spoken w/ Clark, thank you boardbysled
Any steel is an alloy.
Thank you caption obvious :awesomework:
My point was using mild steel (alloy) will not do the job as its too soft and will easily warp plus the alloy used in brake rotors is also designed to disapate heat better.
Those rotors are designed for dry applications. I don't know why guys run them up here in the NW where it is wet and muddy. The holes fill with mud and then your braking performance goes downhill.
Yeh they are bling, but I'll take OEM replacement rotors over those any day.
I thought so too......till I saw all my friends with Spider9's, hi9's, what-have you.....and I can say that (and I'm still shocked!) they worked fine. No issues to speak of......not even a rock caught in one of the many holes. And even no cracking (yet).
:eeek:
I'd run 'em.......For what it's worth.
They may have worked fine but they are still designed for dry applications.
Design? Blah........Pretty sure Terry will be getting them anyways.:;
See if clark can cut them out of stainless steel :awesomework:
We'll see how they work out.
They'll never work......I read it on internet.:flipoff:
Clark recommended using an outfit that does laser cutting as opposed to plasma due to the need for tight tolerances. He also recommended TubeWorks. I thank him but I think my wallet might be a little upset :eeek:
Are you planning on opening a sawmill?, I just ordered up these bad boys. We'll see how they work out.
