T taliwaker Active Member Joined Dec 15, 2007 Messages 28 Location auburn Jan 26, 2008 #1 i cant figure how to wire my 22r out of an 83 yota in to an 81 cab. the plugs are different and theres more wires on the 83 cab. what do i do any one have any suggestions
S skrause Well-Known Member Joined Apr 3, 2006 Messages 9,167 Location Duvall Jan 27, 2008 #2 Use your 81 wiring?
T taliwaker Active Member Joined Dec 15, 2007 Messages 28 Location auburn Jan 27, 2008 #3 im trying, but the plugs are different then the 83 plugs on the motor. and the wiring harness has less stuff on the harness then the 83 harness.
Y yota8 Well-Known Member Joined Jan 15, 2008 Messages 1,424 Location Oakharbor, WA Jan 27, 2008 #4 Get the correct wiring harness.. and are you sure you have the right computer... just checkin :awesomework:
S skrause Well-Known Member Joined Apr 3, 2006 Messages 9,167 Location Duvall Jan 27, 2008 #5 taliwaker said: im trying, but the plugs are different then the 83 plugs on the motor. and the wiring harness has less stuff on the harness then the 83 harness. Click to expand... Swap senders from the 81 and block off any leftover unused stuff.
