al1tonyota said:Thats a nice setup! I don’t know how those rotors would do driving on the road? Probably pretty expensive also?
Bebop said:Correct. Burkey sells a kit with Wilwood calipers, those hats and rotors and mounts for around $800 an axle.
redneckengineered said:Price went up. I entered coupon code "Frenchie" but it went up even more :flipoff1:
http://bustedknuckleoffroad.com/Branik-SUPERDUTY-Brake-Rotor-Package-BSDBP865-or-BSDBP8170.htm?categoryId=-1
Bahahahahahahahahahahakmcminn said:Frenchie only goes down. You must have spelled it wrong.
redneckengineered said:I'm not smart enough to answer this but what are the general thoughts on using 3/8 plate as a rotor?
Bebop said:The moon buggy I have in the garage uses 1/4 mild steel plate rotors (Currie setup). Works damn good and you can't see any real wear on it.
I wouldn't be too afraid of running one.
My front axle didn't come with brakes any way, so had to get something. I wanted a little more clearance between wheel and caliper, as much as I wanted to save weight.rockwild said:thinking out loud here but why are people spending so much money on making the brakes lighter?
Ultra4 rig I can see it - a little
comp crawler - you at water or weight to tires
trail rig - not worth the money
Mine didn’t have brakes either.... the Chevy parts were cheaper than the ford and going to run a Chevy rear so pattern matched. I bought calipers and brackets yesterday so I’ll have a total soon.Dirt700 said:My front axle didn't come with brakes any way, so had to get something. I wanted a little more clearance between wheel and caliper, as much as I wanted to save weight.
Thanks, definitely will be helpful info in the future. I really like the unit bearings, and hopefully the ball joints hold up.al1tonyota said:Mine didn’t have brakes either.... the Chevy parts were cheaper than the ford and going to run a Chevy rear so pattern matched. I bought calipers and brackets yesterday so I’ll have a total soon.
Dirt700 said:Thanks, definitely will be helpful info in the future. I really like the unit bearings, and hopefully the ball joints hold up.
I haven't heard of to many, there's a guy on Facebook that is selling an upper ball joint eliminater kit. Said he broke a couple. Burkey supposedly only ever bent one, but I think he had 550 knuckles, so I'm sure joints we're a little bigger.onepieceatatime said:Has there been any issues with guys tearing up ball joints yet?
Dirt700 said:I haven't heard of to many, there's a guy on Facebook that is selling an upper ball joint eliminater kit. Said he broke a couple. Burkey supposedly only ever bent one, but I think he had 550 knuckles, so I'm sure joints we're a little bigger.
The guy selling them on Facebook is Nick Barnapplblazerdude said:Have a link or anymore Info on this? The ball joints are the same between 99 and present I’m 99% sure. It’s just the size of the knuckles and c that’s different.
Not sure on the 550 stuff though
I have 99-04. I change myDirt700 said:The guy selling them on Facebook is Nick Barna
Are you running a sd 60, and you had any problems?
BeerJ has been running one these axles for about a year now, with good success. I figured he would chime in sometimepplblazerdude said:I have 99-04. I change my
Ball joints once a year. They are still in spec when i change them. I have gone to grease able this year and will see if that helps any.
Not broke any yet but trying to prevent that’s. Looked at the dynatracs but they are just to dang expensive
