Spanaway Mudder
- Joined
- Sep 25, 2007
- Messages
- 3,871
My works rig that I use for installing.. Keeps going thru Crank Position Sensors... ALL of the sensors have been replaced, including the fuel pump...
Last week it died on me so I got it towed home... Yesterday I replaced the CPS with the 10th 1... 1st one I did tho...
fired right up and no problems... made it about 5-10miles away and there it went again with that dieing ****.... would fire back up, then die... did that probably 4 times before I just let it sit for a bit, then fired it up and reparked into a decent spot.. let it sit for 20 mins....
A friend showed up and disconnected the TPS and it fired up no problem.. but then it wouldnt down shift or anything so I plugged it back in and disconnected the battery terminals and let it sit for 5-10 mins while it reset...
tired of waiting in the cold I hooked it all back up and it fired right up like nothing happened.. when running, it runs top, nice strong drive train (figuratively speaking)....
Well today I go out to it to head out for some work and there it goes again with its not wanting to stay running **** again.. fired it up, was situating the inside for my dogs, walked around to get in it and it died... acted like it wanted to fire back up a few times, but wouldnt do it...
basically we have come to the conclusion that either we find a ECM for it or part it out.... I need it for WORK....... soooo..
PLEASE HELP!!!!
PLEASE HELP!!!!
