I
InDaShop
Guest
x
x
x
POPS58 said:The part number from Motion Industries is 124277 and runs $ 89.90. This is very classified information please don't let it out :flipper: :flipper: :flipper:
blacksheep10 said:can you put the pillow block on the OD of the female part of the slip right up against the ears? it would take like a 1.75" or more bearing, but that would do it.
I do not but I need them.P said:OK , so who has "weld in " joke and spline part numbers ???? Spicer stuff obviously....![]()
go check yours. you see in your pic that big nut holding the center yoke on the short upper shaft? that nut has to tighten down on something. that something is the front of the yoke. the back of the yoke is seated on...you guessed it, the inner race of the bearing. that is what locks the bearing to the intermediate. there is no fore and aft movement in your short shaft wyatt. only spherical movement for tcase up and down stuff.InDaShop said:you are making this to hard.
the bearing is slipped onto the intermediate shaft and rides in the bearing its not screwed into or bolted or welded to the shaft, so there is some slop for the short shaft (transfer to pillowblock to slide a little bit.
then obviously the slip is on the shaft to diff section of the driveshaft.
