betteroffsingle
- Joined
- Jun 26, 2012
- Messages
- 139
- Reaction score
- 22
2014 CR Fab buggy
110" wb
72" roof
16" belly
82" wide
Right hand drive
Rock Assault 9 axles front and rear
Rear disc brakes
'99-04 Superduty outers
5:38 gears
HI-9 front with Detroit locker
Rear spool
Branik shafts front and rear
Rear disconnect
22RTE on propane (gotpropane)
Turbo is from Gotpropane
R151F 5 speed
Single 4.7 case
PRP seats, heated, have covers also
5 way harnesses
10 inch PSC ram
50 degrees of steering
39 red label crawlers on Method beadlocks
1 spare red on a different beadlock
Aluminum lower links
1-1/4 lower heims
Fox 2.0 shocks
Limit straps on all 4 corners
Has cutting brakes but without a selectable rear they don't function as true cutting brakes
12K winch with syn rope and 2 remotes
4 propane tanks
LUX rock lights
Rear mount radiator with electric fan
Coolant runs thru the chassis, makes a full circuit of the buggy
Weight is more than the pic, that was prior to running water to the top of the wheel up front
Buggy is super capable, likely moreso than the driver because I don't beat on it. If I can't crawl it, I'm not bouncing it off the limiter, I ain't ashamed to pull cable. No clutch drops, don't drink so no liquid courage "hold my beer and watch this" type stuff.
Some people ask "Why right hand drive?" Beats me, I bought it this way.
25K
Might consider a trade for a solid notchback foxbody. No hatch, no automatic, no verts, no carburetors, no modded to hell drag setup. Only equal or less value on the notch. Not adding money on my side.
110" wb
72" roof
16" belly
82" wide
Right hand drive
Rear disc brakes
5:38 gears
Rear spool
Rear disconnect
R151F 5 speed
Single 4.7 case
5 way harnesses
10 inch PSC ram
1-1/4 lower heims
Fox 2.0 shocks
4 propane tanks
LUX rock lights
25K
