For Sale TUBE CHASSIS ROCK BUGGY
bronco69drp
New Member
Price: 35K
Trail ready crawler built with comfort & drivability in mind.
Comfortable to just trail ride in all day with the performance to tackle any hill or obstacle.
Full tube chassis(1.75 od/.120 wall)
Chromoly links(heat treated)
42" tsl's on steel beadlock wheels
Hi-pinion front d69 with 35 spline chromoly axles & drive flanges
Rear d60 with chromoly 35 spline axles
Front & rear ARB lockers
ARB compressor & tank
5.38 gears
Hydraulic steering
4 wheel disc brakes
Dual(front/rear) wilwood master cylinders
Fox 2.0 dual rate coilovers
Ford 347 stroker blueprint crate engine
HP & Torque: 415 HP / 415 FT. LBS
Cylinder Heads: BluePrint Engines Aluminum Cylinder Heads
Compression Ratio: 10:1
Camshaft: Hydraulic Roller Cam - .543 Intake / .554 Exhaust Lift and 218 Intake / 226 Exhaust Duration @ .050 - 112° LSA
Pistons: Forged
Crankshaft: Steel Crank - 3.400" Stroke and Forged 5.400" Rods
Edelbrock pro flo 4 efi system Self learning or fully tunable without a laptop.
Aluminum radiator with spal electric fan
Electric water pump
2 external transmission coolers with electric fans
External engine oil cooler with electric fan
C6 transmission with art carr shifter
Atlas II 3.8 ratio transfer case
Ramsey 9k winch
15 gal poly fuel cell
½" thick uhmw belly pan
Prp suspension seats
Crow padded shoulder 5 point harnesses
Led rock lights on all 4 corners
Forward facing led light bars
Boss Bluetooth stereo
Rear latching trunk aera with recess for 32 quart yeti cooler.
All side & floor panels fabricated with dzuse fasteners for easy access.
Feel free to message me with any Questions.
