k2blazen
K so I Rebuilt this early 90's motor Replace the clutch" Cheap one" from O'Reilly's$120. Came with a one piece Throw out bearing/housing 1st time I've seen this style when buying them in the past. Installed everything motor runs great its idealing at 850 rpm's.I Go to shift into gears I can't get engage to any Gears. So I figure I need to go get a slave cylinder/Master this morning and It still doesn't have enough throw to engage the clutch.So I Pull the tranny before work t just double check Somethings .Found nothing wrong I'm leaning toward getting Another OEM Throw out bearing housing .I Double check the part number of t he clutch to make sure is Correct.
Last time I run into this problem my v6 Toyota my clutch pedal assembly Was ****ed And twisted .Iam flustered pissed If any buddy got any ideas Let's hear It .The throw out bearing Seems not to be engaging into the fingers of the clutch Like it should be.I can start in gear and wants to lunge forward. I've done quite a few trannies and clutches of my day Seven to ten year For the past 12years But yet I'm not perfect,so the old clutch Works great .I just figured replace it with new while I'm down that far.
yes All hydraulic components ar bleed right Manually and vauum bleed.
Note I posted all this on my phone so Some of the wording could be wack:redneck::cor
