Alright my gauge pod is almost installed. 3 questions
1. The oil pressure gauge is reading @ 95psi at idle and somewhere around 100-105 under throttle. This reads as yellow-red on the gauge... Is something wrong? should it be around 50-60psi (green)?
2. Where should I plug in the Water temp sender? I'm afraid to unplug the one on the intake mani. Are there any other ports?
3. When splicing into a wire, in my case the dimmer switch, does the direction of the splice matter? I'm getting a reverse effect, when the dash lights are on the gauge lights shut off and vise versa.
It's an 85' 22r if that helps at all.
