i have a 83 yota with the 22re the efi is from a celica i believe. it was running fine then just started cutting out. idles fine but with any amount of throttle it bogs down.... and at wot it goes back almost to an idle... changed the fuel filter, checked plugs and plug wires. tried unplugging the 02 and tps and it does the same thing. cleaned the throttle body. check for kinks in the fuel line cleaned out the gas tank... just needing input on what to expect. was just doing it after its warm now it seems to do it on cold start also.. ??? ??? ???
