PHILLBILLY1
I swapped a 22re into my '79 2wd pickup, and I just about have it running, but I cannot seem to get fuel out of the injectors. If I spray starting fluid in the intake, it will fire, and then die. Is there a specific relay or something that I may have not hooked up? I have the main fuse box under the hood with power to it, I have spliced my ignition wires together, so it works from the factory stuff there, I have the O2 sensor hooked up, and I have an EFI tank/lines swapped in it.
Yes, it has great fuel pressure too. I cracked a line up by the intake and checked. I am getting fuel to the injectors, just not out of them.
