I bought TooRiskys 22RE of of the wrecked 4runner. He said they did a compression test on one of the cylinders and it only had 30lbs, not sure which cylinder. Its a fresh build with around 5k miles on it I believe. I pulled the head off it today and found nothing wrong with the valves or the bottom end. he was guessing something may have happened to the valves from the sudden impact killing the engine when he got in his head on collision, but like I said, I see nothing wrong and everything still looks brand new. The engine really doesnt look like it took much impact at all. The only real damage is the fan and the waterpump pulley has a very slight bend. My only guess is the timing chain jumped in the accident but I dont know if that would cause the low compression or what.
Can any of you think of something else I should check before I start to reassemble the engine? My plan was to pull the head off my engine and swap it onto the new block but I'm not sure if thats even worth the trouble if I dont have to. My truck is an 85 and I believe the new engine is an 89. Do I even need to swap heads or should I just put this one back on and do a straight up swap?
