Forbanger said:Unless you're the guy traveling to all the county fairs taking money at the mud pit, this is probably not a good idea. Just run the same gearing.
It has 43s, I don't really plan on racing, just trail ridingTBItoy said:I'd put 4.56 in the rear only. Leave 4.30 in the front
I'd bet a dollar that it will handle better in virtually all situations
Plus if you decide to run cut 44 Boggers, V treads, bolted turf tires, whatever in the rear (ever) then you'll be back to 1:1 also.
I'm assuming you are planning to run 43 SX....
I'm not about doing it now, if I do it will be 4:56 rear, that way if I don't like it I can just change front to match. I probably should just stick to original plan and run 4:88skmcminn said:I would go to a lower gear if anything a 4.56 or 4.10
Dirt700 said:I'm not about doing it now, if I do it will be 4:56 rear, that way if I don't like it I can just change front to match. I probably should just stick to original plan and run 4:88s
3.0kmcminn said:What ratio case?
Dirt700 said:It has 43s, I don't really plan on racing, just trail riding
Spools front and rear, only front steerTBItoy said:What diffs? Spool rear? Front steer only?
I was thinking low speed handling actually, like crawling around tight turns and stuff,
Crawl with first. Bang with second?BUG-E J said:Mine are 4.56 with a 3 to 1 case. If first was any lower it would be useless. I use 2nd the most
I'm fine with 4.56, just didn't know if it would work with the 4:30s. My rear right now is 4:10BUG-E J said:Mine are 4.56 with a 3 to 1 case. If first was any lower it would be useless. I use 2nd the most
The main reason I picked 4:88 was for the 10" ring gearBebop said:Mine's 5.13 with a 4.3 case...
Stupid low, don't do it.
I'd do 4.56 or 4.88. I'm not sure there is a hugely perceptible difference.
Dirt700 said:The main reason I picked 4:88 was for the 10" ring gear
Yeah it actually does good in first but goes straight to the limiter if you go over half throttlekmcminn said:Crawl with first. Bang with second?
Definitely, I'm not sure if 4:10s and 3:0 tcase would be very good,and seems like it would add stress to the rest of drive train. It would be easier to do tho since rear is already 410.kmcminn said:4.10 and 4 56 are stronger than the 4.88s
