So here is the deal. I suck at wiring and have come to the point, which i know i am gonna dread the most. So I am doing my best you just gotta hang with me. I have searched through the internet and my answers are howell harness/painless/etc. or go the wazz and crash route and build my own. Im with wazz and crash on this one even though i should go the easy way out.
So here goes. Motor has almost ever pluged filled.
Parts which are hooked up
Fuel Pump Relay (right cowl, above blower motor)
Fuel Pump/Oil Presure switch (top rear of engine, near distributor)
Variable tuning control relay (engine compartment right side of cowl)
Variable tuning control soleniod(center top of intake manifold)
Heated oxygen sensor
Manifold absolute pressure sensor (left side of plenum)
Throttle position sensor (top left front of engine)
Engine Coolent Tempature Sensor (front of engine)
Distributor assembly
Idle Control Valve (top front of engine near a/c Compressor)
Linear EGR soleniod (top Front of engine)
Knock Sensor (both left and right of cylinder head)
Parts/wires not yet hooked up
Fuel Pump and sender (using a e2000 pump)
Evaporative canister purge solenoid (would like to get rid of)
intake air tempature sensor (homemade intake need to add the IAT in the intake duct
Vehicle speed sensor (possible grounding so its in park all the time?)
Data Link connector (cant find this guy)
Brake Fuse/TCC/Brake Switch (Can i bypass this?)
Below are some picture that i hope you can look through and tell me whats what and where it needs to go.
The code on the PCM
Serv. No 16197427 BNBH
*86BNBHK643560666
Unknown Plug #1
The code on the PCM
*86BNBHK643560666
Unknown Plug #1
