smbroady82
Lets hear it, pros and cons of both LS style 5.3 vs 6.0, other than cost obviously.
smbroady82 said:Lets hear it, pros and cons of both LS style 5.3 vs 6.0, other than cost obviously.
jeff150 said:I've seen you drive. Prolly stick with a 4.8.
muddinmetal said:Older 5.3s have more hp out of the box than the 6.0s and cost a ton less. But, if you get a 5.3 and are the least bit unhappy, you will always think of how you should have went with a 6.0. 6.0s can run l92/ls3 heads, which 5.3s can't. The all aluminum 5.3 ho may be a good option for you to keep weight down
Eddyj said:Cheap 5.3. It's an off-road toy not a drag car or show car.
You get it hot or blow it up you pick up another one and pop it in.
redneckengineered said:6.2L be somebody
Step up...redneckengineered said:6.2L be somebody
smbroady82 said:what kind of interest rates do you charge? lol
tonybolton said:Step up...
2016 CAMARO ENGINE 6.2L LS SWAP - $9000
http://asheville.craigslist.org/pts/6043292181.html
redneckengineered said:Haha, for real though get a 6.0. Used to be the 5.3 was the super economical choice but there are 6.0s everywhere now and they are way more versatile. Run it stock with a tune but have the ability to swap heads, cam, etc and make stupid power.
The-Boss said:I agree with what has already been stated. But to simplify, I think everyone means if you are going to leave it bone stock go 5.3 unless you go with something like a stock LQ9 or LS2 obviously. Advantage to something like a LQ4 or better is there is a lot more potential if you ever want to modify it.
smbroady82 said:Tony, I'll refrain from making another $ joke with you, I think we've all seen enough to last us the next decade. lol
TBItoy said:I'd have to build a rig with a dirt cheap high mile 4.8/5.3, get my dual steering pumps, coolant connections, headers, fuel system, oil pan/oil system, wiring harness, etc etc all sorted out, wheel it for a bit then build a stroked 6.0 to bolt in its place when $ allowed.
stuftmunky2k said:Turbo 4 banger
