skipnrocks
So my buggy turns ok. But not super sharp. But I noticed the last time out that the outside tire turns significantly sharper than the inside. Then I got to thinking this is backwards than what I thought was supposed to happen. So my question is is this normal good or bad and can it be swapped.
This is on a Dana 6 front with high steer arms. Psc 2.5x8 double ended ram mounted in an artec front truss. So fairly common setup. But it's quite dramatic difference between steering angles on each tire
