10 to 15 for all around wheeling is good as low as 2-4 for the snow. When down low though try not to spin your tires as its real easy to pop a bead.(spin the wheel in the tire) Also when your aired down its much easier to pop a bead if you hit the sidewall with something (roots, rocks, ruts) be prepared to be able to reseat a bead if needed.
Quote:
Originally Posted by cal I've run my 315/75/16's on 16x8" wheels at 8 PSI without a problem. Never has my keyboard lost a bead, and my mouse never falls off the pad.
Thanks for the input! I wasn't sure how low I could go before I really started risking popping a bead. I stayed safe last time out and kept it at 22. I'll give 14 a try and see how that goes.
