wayne86
I am seeing a lot of guys using the support ring around the rear output on the Atlas. On my 1.25" adapter between the trans and tcase there is a built in block to bolt to a crossmember. I have a rubber block that was on my dana300 adapter that I took and bolted onto the adapter. I was just going to weld that to a crossmember between the frame rails. My question is, should I still do a support ring too, or is the crossmember under the adapter enough? It seems the support ring welded to a crossmember like from WOD would work well with poly bushings bolting the crossmember between the frame rails.
