AX15 Clutch
L
lowbudgetjunk
Guest
Anyone have any advice on what to get or what to avoid on a stock AX15?
Been researching until my head hurts. Trail use only with 4500 pounds to lug around. 4.88's in diffs with a Dana 300 transfer case. Sitting on 39.5's with a stock 4.0
Sent from my LGL62VL using Tapatalk
Got mine at oriellys 2 years ago. Same set up as you but 5:38's. I researched like you and finally got tired of varying opinions and got stock replacement..I'd do it again......
Thank you dear lord. I was starting to feel like i was missing the boat on this. I almost went to the parts store and said oem please. Thanks for the honest replies.
Yep stock replacement here too. About the same setup. Still has the same smooth but firm pedal
I love my oreillys clutch the throw out bearing is a different story though.. I've had to replace one every year since I installed the parts house clutch..
I used a centerforce stage 2. Been in the jeep since 04.
It has weights on the pressure plate for extra holding power.
I have a 4.7,ax15, with d300 and wontons and 42s.
