Forgive me if this is a "newb"-esque question but...what is the most likely cause of lower ball joint wear? or ball joint wear in general?
background info:
Dana 44 front axle (Chevy-late 70's I believe). Pass drop, LP w/ 5x5.5 bolt pattern, 15x10" steel wheels (4" bs) and 38" Mickey Thompson MTZ's.
I went to get an alignment on Saturday morning and (granted, I don't know how I hadn't noticed this) the tech grabbed my wheel and rocked it back 'n' forth while everything else stayed completely still. Quite a bit of slop while the vehicle was raised off the ground. Could easily see the lower ball joint floppin around.
Just thought I'd ask about potential wear-causing factors to see if I could prevent having to regularily replace ball joints.
Terry
background info:
Terry
