bolt yankin' help
Zap
Seattle
How do I get the forward bolt on the passenger side rear leaf spring to back out?
The gas tank is too close to hit it with anything or get good leverage with a prybar.
Help. . . ? :wtf:
Thanks.
EZ
Help. . . ? :wtf:
Thanks.
EZ
Would help to know what kind of rig you're working on... :;
Help. . . ? :wtf:
Thanks.
EZ
Is it stuck and won't move at all? Or you just don't have enough room to totaly remove it?
Oh yeah sorry. 85 Toy.
It'll turn, but won't back out. I have some nerf bars I want to install. They attach to the tranny cross member and the bolt I'm having problems with. The driver's side is not an issue. Just the passenger side since the gas tank's in the way.
Thanks for the quick replies btw.
The bolt is siezed in the metal sleeve--typical issue. I have gone as far as to burn the bushing/cut the head off and use my air hammer...
If you burn them out and need some stock spring bushings, I've got a few kicking around. Send a PM if you need one. Might have one of those bolts too.
weld a rod or large washer onto it and then pull it out with a slide hammer.
Or weld a 6" piece of allthread to it then slip a deep socket over the bolt (big enough for the bolt hed to fit in) Then stack a couple of washers on the allthread followed by a nut and tighen the nut drawing the bolt out through the socket. You may need to grab the end of the allthread with a pair of visegrips to keep it from spinning (after you thread the nut on)
skrause said:
Impact spinning it while you wedge a prybar somewhat gently behind it. Works every time. :D
I'll try that first.
pokey weld a rod or large washer onto it and then pull it out with a slide hammer.
I'll try that second.
cisco If you burn them out and need some stock spring bushings, I've got a few kicking around. Send a PM if you need one. Might have one of those bolts too.
If I try the second one, definitely expect a pm from me. lol
Thanks you guys for the help. I'm trying to save my pretty rocker panels, but if I wait for my buddy Ken to fab up some rock sliders, my kid will be old enough to drive by the time he gets them done. :flipoff: @ Ken. :stirpot: :corn: :D
With "nerf" bars? :haha: You know you're gonna end up doing more damage if you actually put them to use. Brace them suckers gooooooood.
You think so?
We thought of notching the folds and or the nerf bars themselves. We were gonna weld them to the frame a little too.
They're big thick smitty built ones. Am I fooling myself?
Zap said:
You think so?
The mounts suck. The tube sucks. If you actually USE them they WILL bend everywhere. Somewhere I have a pic of someone's ****tybuilt nerfs "frowning" if you know what I mean. :haha:
the smitty built nerfs are what I have on mine, and you can flex them by hand if you want too, they do ok with stumps and keeping the body away, but I would not lift on them or expect them to hold up on rocks.
Had one smash into a rocker panel when I had them. Worthless except as a step in stock form.
Good one here...:cool:
