Brakes
Jduck
Athens, GA
YJ body with stock booster and unknown make of ford master, has 1 3/8" printed on side for bore size I'd assume. Have 2lb residual valve on front line, and adjustable porp. valve on rear line. Chevy 60 front with stock calipers, 14bolt rear with 3/4 ton calipers. It stops well but has a shitty pedal...soft and excessive travel. Was thinking I needed a smaller bore master so I picked up a 99 dodge 2500 master with an 1 1/4 bore but now Im second guessing if that will make any difference or if I need to go up in bore size instead of down...
I have the dodge Mc on mine and it stops great with a good pedal feel.
Sent from my SCH-I545 using Tapatalk
I ran a e350 mc on a factory yj booster and the same calipers as you for a long time with low gear crawling and got used to mediocre brakes. My wife started driving and I got instant feedback about how shitty the brakes were. I picked up and superduty hydroboost and mc. The damn thing has kick ass brakes for sure now and everybody who drives it loves them. $.002
Dwalk said:
I switched to these on the front with stock YJ M/C and booster, better than ever now.
http://www.tmrcustoms.com/store/index.php?main_page=product_info&products_id=1622
I think that's going to be a better idea than the guessing game of what master cylinder. I've broke front brake lines twice and crimped them off, after doing that the pedal felt the best with only three calipers grabbing so that would indicate a volume problem id think. Probably going to go with this kit from Shawn https://lugnut4x4.com/product/dana-60-front-34-ton-disc-brake-conversion-kit/
