Ported Hydro Boost Brakes FTW
BustedKnucklefilms
For this week's Tech Tuesday we are talking about hydro boost brakes and why they are the perfect solution for giving your trail rig better brakes.
Will cutting brake work with the hydro boost? And if i got the hydro boost and the biggest orbital valve yall sell do i need to upgrade my stock pump on my ls gen 3 or will it work ok?
If you have a stock pump you should use a stock flow hydroboost setup. We can set you up with one of these without all the high flow porting. Never used a cutting brake but if plumbed correctly I don't see why it wouldn't work.
