uphill said:yes it will, all the motor be fit for then is quarter mile, shut down and cool down,
ratedX said:Its a 430 4.125 bore 4.100 stroke ls2 block
Plus you would use almost double the alcohol than gas, and alcohol draws a ton of moisture, we would have to change the oil every other time we raced, looked like white chunky buttermilkElliott said:I'm betting some one runs alcohol before to long, Great cooling, instant response with a toilet or terminator and more power! I've been debating trying it on mine, I've even called Ron's to see if they had a barrel valve that would drive around a little better, but they said no that the throttle would just be an on - off switch
