Boonie's 1/2 right. :flipoff:
Lots of grinding, but not that bad.
First side will take forever, second side will take like 5-10 minutes. Get a couple good grinding wheels for your favorite grinder. Start grinding at the weld at about a 45? angle (INTO the knuckle a bit). Your looking for a "part line" to appear, these means you've gotten all the weld out thats holding the two parts together. DO NOT try and turn them till you see this line all the way around.
Then get your favorite BFH and beat them to the angle you want/need. I've found it easier sometimes to actually beat them off, then clean them up *just a little* and pound them back on closer to the right place.
Before you remove, measure the top and bottom ball-joint widths, then double check it before you weld them on. Its possible to get the camber off just a little if your not careful.
when your happy, BURN THEM IN.
First sides a bitch cause your constantly looking for the line. Second side is easier since you have an idea how much to grind.
Wear safety glasses, gloves, ear protection and a mask.... unless you like black boogers :redneck:
________
LAMBORGHINI 350GTV SPECIFICATIONS
