Nope, it's controlled by the idle air valve which is under the intake. It gets gummed up and won't open anymore. Upgrade to the 88 or newer throttle body to get rid of it, direct swap. Just make sure you get the TPS off the newer one, you'll need the little metal plate that contacts the throttle.84Toyota4x4 said:Looked quickly and couldnt find a spec in the FSM. They only tell you how to set the regular idle speed for the 22RE, but its an 85 FSM, so maybe a newer one? I dont know that its even adjustable since I think its ECU controlled...
~T.J.
Sure, but it'll happen again. Poor design.Jay1 said:Is their a way to adjust it or clean the air valve?
As I recall you can't really open them up, but you can spray it out with carb cleaner.Jay1 said:Is their a way to adjust it or clean the air valve?
