d30 fancy outer seals
greenie
the burg
the stock outer plastic seals, if you could call them that, wouldnt go around the larger diameter neck of the ten factory shafts i put in last spring, so i been goin without. can anyone confirm which of these fancy seals will work: http://www.amazon.com/Alloy-USA-111...1382119397&sr=8-3&keywords=dana+30+axle+seals
the company sells a set for regular, or 30 splines. i just have the regular 27 splines but not sure what the diff is in neck diameters, like i said the stock plastic no worky, shafts too big. Its a ZJ.
If you are talking about the ZJ shafts with U-joints. Cut those shaft seals off and throw them in the garbage.
If you are a mud slut than you probably need them, otherwise they can go the way of the dodo. :awesomework:
