truckbroke
Anybody got a Dana 60 spindle boring tool they want to rent? Don't need it right this very second but, just wanting to go ahead and ask.
Rokcrler said:Just a heads up. The replacement bits are pricey if/when you burn one up.
I have the tool but it's one of those "hate to..." type of tools.
TBItoy said:people still run D60 rears? ???
Right, but I think the main thought it is generally cheaper to put a 14 in there or something rather than bore, buy good shafts, still have a 60 with a smaller pinion shaft (and everything really) A blingin ass truss and link mounts or a set of deep gears and good locker (you're changing locker going from 30 to 35, might just get side gears) is the only reason I can think of for not swapping now. If you do have good guts in the 60, they can be moved to a 60 front as long as you can swap side gears, so there is still value theretruckbroke said:Lol.. yeah I been in the air. I got a TBI 350 and really just don't see it ever having enough power to break a 60 with 35 spline shafts. I've broke the Yukon 30s a few times already. No I didn't build this rig or it would have never of had this in it.
blacksheep10 said:Right, but I think the main thought it is generally cheaper to put a 14 in there or something rather than bore, buy good shafts, still have a 60 with a smaller pinion shaft (and everything really) A blingin ass truss and link mounts or a set of deep gears and good locker (you're changing locker going from 30 to 35, might just get side gears) is the only reason I can think of for not swapping now. If you do have good guts in the 60, they can be moved to a 60 front as long as you can swap side gears, so there is still value there
quite a bit, when i made the 14b shave kit, I was getting right at 2" off the 14 when ring was shaved a bit. Its over an inch more than a 60 stock.truckbroke said:We just did the full shave on my buddies 14 bolt and I was really surprised at how easy it really is to be honest. I been meaning to pull tape on my 60 and his shaved 14 bolt. We both run 43s and the same width wheels. I'd just make sure the air pressure was the same and really see how much a shaved 14 bolt beats a 60 for clearance.
