Drive line ?
Trailabite
Clarksville, TN
When I'm in 4 low or 2 low everything seems to work just fine. When I go to 4 hi it takes a good bit gas to get my jeep moving. It kinda feels like the brakes are on. I can't get up to speed and after a mile down the road my jeep is over heating, any ideas? I can go 4 wheeling all day and as long as all of the trail are close together I have no issues at all, but when we go from trail head to trail head and have to run in hi gear I have problems.
My specs:
Ramjet 350
TCI T350, with reverse manual valve body
4.3 Atlas
Take it out to the MOAB OUTPOST and let them drive it and see what there opinion is, they know there stuff
Re: Re: Drive line ?
bjeep said:
I would check to see if a caliper is stuck. :****:
That too... Just this past weekend, I rode in Tracy city, probably drove 10 miles total on the road, and several in our group had stuck or dragging brakes.
How's your timing, have you checked it to make sure it hasn't moved, that could make it a turd when in higher gear, but less noticeable while in low gear, would also let the cylinder temp increase causing some heat issues. Just a thought.
