I am building a two peice front for my buggy. The first half coming off the tcase is going to have a pedistal mount bearing on the splines and the yoke will slip on downstream of that. The dline coming off the tcase will be at about a 10degree down angle. My question is, do i need to have a slip yoke between the bearing and the tcase, i dont think i do cause in my mind the dline will not move out or in if it is held on the end with the bearing, but i am doubting myself and i keep picturing a ujoint rotating in my mind to work this out. If it does try to travel out and in on rotation and i fix it in the bearing that will tear up something, most likely the output bearing on the tcase with thrust loads.
