run down of kit
Brand: Edelbrock
Product Line: Edelbrock Performer RPM Pro-Flo2 EFI Systems
Part Type: Fuel Injection Systems
Part Number: EDL-35080
EGR: No
Injection Style: Sequential multi-port
Metering Style: Speed density (Map-N) and speed throttle (Alpha-N)
Intake Manifold Included: Yes
Intake Section Included: Complete
Intake Material: Aluminum
Intake Finish: Natural
Engine Block Style: Stock/OEM standard deck
Fuel Rails Included: Yes
Throttle Body Included: Yes
Throttle Body Mounting Flange: 4-barrel square bore
Venturi Quantity: 4
Airflow Rate (cfm): 1,000 cfm
Throttle Body Material: Cast aluminum
Throttle Body Finish: Natural
Injectors Included: Yes
Injector Size (lbs/hr): 35 lbs./hr.
Calibration Module Included: Yes
ECM Included: Yes
Wiring Harness Included: Yes
Oxygen Sensor Included: Yes
Fuel Pump Included: Yes
Fuel Pressure Regulator Included: Yes
Distributor Included: Yes
MAP Sensor Included: Yes
IAT Sensor Included: Yes
TPS Sensor Included: Yes
IAC Motor Included: Yes
Quantity: Sold as a kit.
Notes: A laptop or PC is required for initial flash set-up. A CD and USB hook-up are included.
Multi-Port Fuel Injection, Performer RPM, Pro-Flo2, Speed Density/Throttle, 1,000 cfm, Mopar, Big Block, Kit
Check to make sure this part fits your application Pro-Flo2 fuel injection from Edelbrock.
These Edelbrock Pro-Flo2 (Pro-Flo second generation) systems are complete fully-sequential EFI systems with all-new, powerful electronics packages that include everything you need to convert a carbureted engine to a modern fuel injection system. Starting with a new flash-programmable engine control unit (ECU) powered by EFI technology, a leader in advanced electronic engine management and monitoring systems, the Pro-Flo2 systems allow for more tuning features, fully sequential injector firing, and limitless calibrations in a compact package. The Pro-Flo2s include a new software package with a graphic user interface that is user-friendly and has an updated look. Additional software features include Edelbrock's exclusive hand-held calibration module (for tuning without a laptop), and new for the Pro-Flo2s is the option to laptop-tune--this gives you the best of both worlds! Two tuning strategies include speed density (engine speed vs. manifold absolute pressure) and alpha-N (engine speed vs. throttle position). Included are base calibrations for common AMC, Chevy, Ford, and Chrysler applications. A narrow-band O2 sensor is included, but the Pro-Flo2s are wide-band 02 compatible.
The complete packages include:
* Intake manifold
* Throttle body assembly
* Fuel rails
* Fuel injectors
* All sensors
* Wiring harness
* ECU
* Hand-held calibration module
* Software
* Brackets
* Attaching hardware
