Electric Fan Jeep YJ
rpf500
Evansville, IN
I searched and found a thread from Kush, but after looking in to it more, both the Volvo and Taurus fans are too big for my application. I have not seen either in person, so I am not sure how much can be trimmed down, but both are in the 22"+ range on the shrouds and I have only 18" x 18" to work with. Well, that is what needs covered atleast. Any wider, and I get into the inlet and outlet, and any taller I hit the hood or my steering will hit at full bump.
http://www.hardlinecrawlers.com/forums/index.php?topic=39762.0
I can find the shrouds online at Summit and add a fan. Some guys do this, others buy the cheap units with a guard on them basically and say those are working. Can anyone tell me what they use for a fan, and about how many CFM I need to be looking for. Higher the better on CFM's I am sure. But what are you getting by with now is what I am after.
I have ran parts store fans on everything you can imagine since I have been driving. Buggy has 2 on it. Only problems I have are those dumb pull tie things they come with. Unless I was wanting to spend the money on an entire unit (radiator shroud fans plug up and go) I will continue to go this route.
YJ....Taurus fan inverted in front of radiator
That is a thought there. Never crossed my mind. Do you know how thick the set up is total? I ask because if I had to move mine out (towards engine) to fit the Taurus fan, that won't work either because my links/truss will hit the bottom of the radiator. I could tilt the top back some, but the bottom needs to stay tucked up pretty tight against the back of the grill area.
Never measured it....but my upper links would hit the crank pulley before it hit the radiator. It's bumpstopped before that obviously.
Are they just 1 speed fans that you use? I looked at Advanced at they are $65 and 1400 CFM. I can't fit 2, but then again, I have no idea what the factory fan CFM is either so maybe I would not need 2 with my monster 4.0L.
Yes a hot and a ground. How you wire it depends if it pushes or pulls. O rieleys carry a few different sizes. Get 2 small ones if you want and out thwm on. Then just add the 2 cfms together
Thanks a lot guys. I am going to get some more dimensions and see what I have to work with. I want to end up with too much fan, and not one that is too small.
Are you still running the 4.0? I know my buddy fit a Taurus one on his 4.0 Rubicon.
And if you go to the junkyard to get one pull the Volvo relay box. Makes wiring it easy enough for a dude like me who can't seem to do anything right on my rig.
I had the same room issues when I swapped a SBC in my YJ. I saw this syclone fan in another thread on here so I thought I would give it try. I mounted it on the front of the radiator as a pusher. Had the jeep out for the first time on saturday and it worked awesome. pulls more air and way quieter than a parts store fan.
https://www.summitracing.com/parts/flx-398
So no shroud or anything? This one would cover most of my 18x18 area so I'd assume that a shroud would be a waste in that case.
I found this last night. Comes with a fan. It would fit about perfect if mounted sideways of their measurements. I like that yours is a known brand name though.
http://m.ebay.com/itm/NEW-ALUMINUM-RADIATOR-FAN-SHROUD-W-16-FAN-MANY-FORD-MODELS-20-WIDE-CORE-/282085153566?hash=item41ad95db1e%3Ag%3AmAEAAOSwo4pYSxvM&_trkparms=pageci%253Af2451b9f-c118-11e6-895d-74dbd1e0e417%257Cparentrq%253Af79303bc1580a2a21500552fffdd7238%257Ciid%253A9
I have the Summit Syclone fan on my 4.0 and no problem keeping it cool.
I made a shroud out of a price of thin AL tread plate I had laying around. It mounts flat to the back of the grill using the same bolts as the radiator with the fan in front pushing. I had to take the Syclone name plate off the fan to have enough clearance behind the grill slots to fit.
I have it wired thru an adjustable thermostat to a 50amp relay on a SPDT switch on the dash
Always ON - OFF - Tstat ON
I can grab a better pic this evening if you want
Sent from my Pixel using Tapatalk
no shroud, just fastened right to the front of the radiator.
Thanks guys. I ended up with the cyclone fan also. The Amazon gift card I got for Christmas paid for it which was even better.
Any benefit to mount as a pusher vs puller? I have my steering and trans coolers mocked up for behind the grill mounting with the fan as a puller.
You can make a shroud for it. We took a flat sheet of 18 gauge sheet an mounted it right to the stock radiator as a puller. Had a 13" fan in it. Worked like a charm. It never got hot unless some dumb ass forgot to turn the it on. :woot:
