2xwannabe said:the reason they break is because the electrode housing sticks way down into the combustion chamber and it gets carbon build up on it. all you have to do it run a bunch of sea foam or something similar through the vacuum sytem or into the intake and clean the carbon a bunch and it will be fine. or for future reference change the plugs every 60k and you have no worries.
grcthird said:Is #2 one of the cylinders that always gets coolant in it from the thermostat housing and causes a misfire? Or is that only a 4.6l thing? It's late and I can't remember.
