I've been reading up on fuel cells but still have a couple questions- mabey I'm just overthinking.
I thought "fuel cells" had a plastic or rubber bladder and foam inside. So I am looking at the RCI 2161A for my jeep but it appears to have no bladder or foam. In fact many of the advertised "fuel cells" have no bladder or foam.
Wouldn't that be classified as a "gas tank" rather than a "fuel cell"?
And don't "gas tanks" for modern EFI engines have baffles inside to prevent sloshing and sucking air?
So why would a guy "upgrade" to a fuel cell if it's just a hollow aluminum box? Wouldn't the factory tank be safer and work better? (I know it doesn't look as cool but I'm really all about function and safety)
I also read about removing the foam from fuel cells because it messes up fuel systems and engines. Is the foam only required for sanctioned racing use and unneccesary for recreation? Does removing it defeat the purpose of using a "fuel cell"?
Also I was considering using my stock YJ pump module in the 2161A like this- http://www.pirate4x4.com/forum/showthread.php?t=398298 but thought mabey it would be cheaper and easier to use a less expensive cell or tank and get an aftermarket pump but I don't know what works- any advice much appreciated.
